7 members (LAJones48, Barry Martak, Otto Skorzeny, Waveski, Shaffer's1950, Rusty Heaps, 1 invisible),
110
Mod | | | Forums66 Topics128,094 Posts1,056,465 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 14 Apprentice | | Apprentice Joined: Apr 2009 Posts: 14 | The rear drivers side wheel cylinder has both pistons seized inside the housing. I have not been able to get either piston to move. Any ideas, without having to buy a complete new cylinder? In advance, thanks!
PS: This is on my '41 Chevy 1/2 ton
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | soak it for days in pb blaster. I have had some luck with putting air pressure into the inlet. Just make sure you aren't aiming it at anything breakable. What I do is wrap it in a shop rag to contain the flying parts. | | | | | Joined: Apr 2009 Posts: 14 Apprentice | | Apprentice Joined: Apr 2009 Posts: 14 | I started soaking it this morning. Next I'll try the air. Thanks! | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i have had good luck just driving them out. soak them. drive one in a little, clean around it, then drive them out from other side while it in a vise. i use a brass drift, the pistons are like pot metal and can crack but usually don't. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | the wheel cyclinder are usually pitted to bad to rebuild.saftey first .pitch the old ones.NAPA has new one for around $10.ea
dan-pa
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
| | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | replace the cylinder and if it was mine I would make sure the others were good. safety first! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've been down that same road. Buy new cylinders. They are not that expensive. Your time has to worth something. New ones will save you time. It's good to be able to go, but it's better to be able to stop. If well working brakes aren't #1, they are darn sure #2.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | I agree with all the above...replacement is easy, safer and a huge time saver. Old and pitted cylinders aren't worth the hassle. Jim Carters has them if you don't have a NAPA locally.
Hank | | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | $10.00 sounds a little low. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | at NAPA $10 is for the Chinese version, they start leaking in a short while - ask for the spendier one, my local NAPA stopped carrying the Chinese version within a year
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Well, if you want to take them apart, make sure that you apply the force to the ouside of the pistons. If you pound on the center of the pistons, they will break quite easily. Mine were pitted but that is not always the case. | | | | | Joined: Apr 2009 Posts: 14 Apprentice | | Apprentice Joined: Apr 2009 Posts: 14 | fifty 3 is correct. New ones are $75.99 ea. at NAPA. I got the stubborn one apart, not pitted just a long time since it had been used. I've rebuilt them all and just have to bleed them now. Thanks for all the help and advice.
