5 members (LAJones48, 3B, Charles in CA, Joe H, Ridgeback), 133 guests, and 2 robots.
Topics128,092
Posts1,056,455
Members48,443
Apprentice
Apprentice
The rear drivers side wheel cylinder has both pistons seized inside the housing. I have not been able to get either piston to move. Any ideas, without having to buy a complete new cylinder? In advance, thanks!
PS: This is on my '41 Chevy 1/2 ton
soak it for days in pb blaster. I have had some luck with putting air pressure into the inlet. Just make sure you aren't aiming it at anything breakable. What I do is wrap it in a shop rag to contain the flying parts.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Apprentice
Apprentice
I started soaking it this morning. Next I'll try the air. Thanks!
i have had good luck just driving them out. soak them. drive one in a little, clean around it, then drive them out from other side while it in a vise. i use a brass drift, the pistons are like pot metal and can crack but usually don't.
the wheel cyclinder are usually pitted to bad to rebuild.saftey first .pitch the old ones.NAPA has new one for around $10.ea
dan-pa
Buy new
replace the cylinder and if it was mine I would make sure the others were good. safety first!
I've been down that same road. Buy new cylinders. They are not that expensive. Your time has to worth something. New ones will save you time.
It's good to be able to go, but it's better to be able to stop. If well working brakes aren't #1, they are darn sure #2.
I agree with all the above...replacement is easy, safer and a huge time saver. Old and pitted cylinders aren't worth the hassle. Jim Carters has them if you don't have a NAPA locally.
Hank
1951 restoration on website
http://www.hanklong.com
$10.00 sounds a little low.
at NAPA $10 is for the Chinese version, they start leaking in a short while - ask for the spendier one, my local NAPA stopped carrying the Chinese version within a year
Well, if you want to take them apart, make sure that you apply the force to the ouside of the pistons. If you pound on the center of the pistons, they will break quite easily. Mine were pitted but that is not always the case.
1951 1 Ton Completed
Apprentice
Apprentice
fifty 3 is correct. New ones are $75.99 ea. at NAPA. I got the stubborn one apart, not pitted just a long time since it had been used. I've rebuilt them all and just have to bleed them now. Thanks for all the help and advice.
