0 members (), 66 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#633968 04/01/2010 4:18 AM
I was asked to move over to this forum to let you all know what kind of welder i bought.It is a Liccoln easy-mig 140,i can plug it into a regular house plug as long as it is 20 amp,it is set up for gasless flux or gas shielded welding.It came with 2 spools of wire,1 hand held mask,regulator for gas,dvd instructions plus a learn to weld manual.I know the best way will be to get my hands dirty and start on small stuff.Looking forward to it.
Roy
One ear dicky #633983 04/01/2010 5:15 AM
cooool! get a gas bottle and start migin'.
hoggyrubber #634050 04/01/2010 3:01 PM
Yup, go the extra $ and use the co2. You might want to ditch the hand held mask too. about $45 at harbor freight gets you a auto darkening one
gazim #634052 04/01/2010 3:05 PM
My wife bought me a proper mask for christmas last year.This is before i was a 100% sure i wanted to tackle it,GREAT wife!
Roy
One ear dicky #634089 04/01/2010 5:25 PM
If you are going to be welding for any length of time, you need to use a helmet to protect yourself from UV rays. You also need to wear gloves and a long sleeve denim or leather shirt. Also a CO2/Argon mix will splatter a lot less when welding patch panels. I find flux wire of little use except for welding thicker metal in the wind. Make sure you reverse the polarity between gas and flux.
crenwelge #634138 04/01/2010 9:44 PM
Thanks Crenwelge,i know i still have equipment to get,and i've started reading the book and have already learned about the different polarities.One question i have concerns the fumes and smoke if any,do i need to set up a fan to blow away from me while i learn?
One ear dicky #634147 04/01/2010 10:22 PM
[censored] - if the metal is clean and not galvanized you just need to be in a normally ventilated area, no need for a fan unless you're working in a closet, and wind creates problems for the gas doing it's job of keeping an 'envelope' around the arc
squeeze #634156 04/01/2010 10:49 PM
fresh air never hurts. you can bump up your gass pressure a little if you want to run a fan. i personally like to weld by the door in my garage. i can get a headache even from miging if i do it for hours on end, but it's a lot better than arc for fumes. aytime you burn paint or even clean metal has something on it it's best not to breathe it.
hoggyrubber #637290 04/13/2010 1:57 PM
I welded for many years,indutrial welding. Its true work in a well vented area,course an exhaust fan would be a good idea too.That extra air pulling the fumes away sure wont hurt anything.
dale937 #637518 04/14/2010 4:25 AM
Go easy on the exhaust fan, just want to move it not blast it away, if you notice pin holes in your weld you are moving to much air. If I use a fan it is behind me, the area around the nozzle should be protested fron any air.
You Learn more Listening than Talking
Moderated by  MNSmith
