3 members (78buckshot, Phak1, NJC), 88 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#63409 07/24/2006 3:44 AM
Some advice please,1953 3100 3 speed,I bought this truck from a fellow that started the restore
about 8 years ago,sand balasted and painted the
frame,had engine and trans rebuilt,with new clutch.had cab done and back on frame. then it sat in a garsge for about 8 years. Thats when I picked it up,I got it running.rewired it put the bed on and interior,rebuilt the brakes and front end.Just found out the clutch disk is stuck to the flywheel and pres plate. the truck was never out in the weather, anyone think that I can free it up or should I pull it apart. Thanks for any
help..Don
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
#63410 07/24/2006 5:21 AM
You can drive it up a hill with the clutch pedal depressed or put the rear on jackstands, run the engine in high gear and slam on the brakes while the clutch pedal is depressed. Make sure there isn't anything you'll run into if you come off the stands!
#63411 07/24/2006 2:56 PM
You can also try to start it in gear with the clutch pedal pressed. Sometimes that works. wink
#63412 07/24/2006 6:14 PM
Mr. Giant,
Some pressure plates are constructed so you can gain access to the clutch disc after removing the flywheel cover. Maybe some prudent prying with a long screwdriver would do the trick.
This would be the "don't want to drive it" approach!
Stuart
#63413 07/24/2006 10:08 PM
Riding in the Passing Lane
Put it in high gear & prop the clutch pedal down or have someone hold it down. Rock the truck back & forth. This usually gets em loose & you can tell when it comes loose.
1972 Chevy c10 Cheyenne Super
#63414 07/29/2006 5:44 AM
Sign up for a tractor pull, put plenty of weight in the bed, enter, start in 1st gear, hold the clutch down. Something has got to give wink
•1952 Chevrolet 3800 pickup
---All pictures---
