0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63409 07/24/2006 3:44 AM | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Some advice please,1953 3100 3 speed,I bought this truck from a fellow that started the restore about 8 years ago,sand balasted and painted the frame,had engine and trans rebuilt,with new clutch.had cab done and back on frame. then it sat in a garsge for about 8 years. Thats when I picked it up,I got it running.rewired it put the bed on and interior,rebuilt the brakes and front end.Just found out the clutch disk is stuck to the flywheel and pres plate. the truck was never out in the weather, anyone think that I can free it up or should I pull it apart. Thanks for any help..Don | | |
#63410 07/24/2006 5:21 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You can drive it up a hill with the clutch pedal depressed or put the rear on jackstands, run the engine in high gear and slam on the brakes while the clutch pedal is depressed. Make sure there isn't anything you'll run into if you come off the stands! | | |
#63411 07/24/2006 2:56 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | You can also try to start it in gear with the clutch pedal pressed. Sometimes that works.  | | |
#63412 07/24/2006 6:14 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mr. Giant,
Some pressure plates are constructed so you can gain access to the clutch disc after removing the flywheel cover. Maybe some prudent prying with a long screwdriver would do the trick.
This would be the "don't want to drive it" approach!
Stuart | | |
#63413 07/24/2006 10:08 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put it in high gear & prop the clutch pedal down or have someone hold it down. Rock the truck back & forth. This usually gets em loose & you can tell when it comes loose. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63414 07/29/2006 5:44 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sign up for a tractor pull, put plenty of weight in the bed, enter, start in 1st gear, hold the clutch down. Something has got to give  | | |
