1 members (baldeagle),
91
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63380 07/23/2006 1:44 PM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | Hello all. If you remember my post from a few week, I'm installing a disc conversion kit on my '50 1/2 ton. The new front axle is installed and I'm all ready to install the brakes.
I need the hub from my original huck brakes. The directions say to just cut the rivets off and take the hub off. The problem: there are no rivets that I can see. How does this whole thing come apart? Next, the three mounting holes used in the kit don't exist on my hub. There are only the 6 lugs, no extra holes. What am I missing? I thought this kit was built for the huck brakes.
Anyone have any front hubs they want to get rid of? Thanks for any help. | | |
#63381 07/24/2006 3:22 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hey Red,
I've got a pair of front drum/hub assemblies from my recent disc upgrade on a 54-3100 straight axle. Don't know if they are the same as on a 50 but you're welcome to them. They had the rivets that I ground down to get my 6 lug aftermarket wheels to fit flush. Also have the original ball bearings that are in decent shape.
I'm headed north on I-95 next Monday (31st) and would be willing to drop them off. Let me know.
Dave | | |
#63382 07/24/2006 12:44 PM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I appreciate the offer and may take you up on that. But your comment makes me think I'm missing something on my drums. I cannot see the rivets on my hubs. It's totally smoothe in between lugs. But my truck did have aftermarket wheels when I bought it. Looking from the inside of the drum, the only thing I see are the heads of the 6 lugs. I have cut the lugs off, after beating on them with a 2 lb. sledge hammer, trying to remove those and they won't budge. I think I may have to drill all of those out. What a pain. Here is a picture of the drum with the plate for the disc kit. I'll take a picture of the inside of the drum tonight. http://community.webshots.com/photo/552501289/2308430050091368085ImRPqK | | |
#63383 07/24/2006 5:01 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | What you need is someone to jump in with more knowledge than I can provide. I posted a couple pics of the 54 drums in my webshots....at end of "Point Gapping made easy".
The offer still stands if you can use the drums. Hopefully, somebody that can help you out will jump in. | | |
#63384 07/24/2006 5:03 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Try this. You might have to go back a page, but this is a link to the shop manual. http://chevy.tocmp.com/1948_51truckshop/51ctsm0307.htm
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#63385 07/25/2006 4:59 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | According to buffalo enterprises, those 54 hubs will work on a 50 or earlier truck. when using them on a pre 1946 truck you would need to reuse the inner wheel bearing races from the pre 46 hubs.
RedGreen, You wouldn't be related to the guy on TV would you? If so... just use duck tape! | | |
#63386 07/25/2006 11:38 AM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | RedGreen, Let's get on the same playing field: 1.) Where did you get the conversion kit? 2.) What do you mean by "new front axle"?
#63387 07/26/2006 4:31 PM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I keep trying to use duct tape, but people keep convincing me to throw more money at this thing. I think the whole front end is actually gold plated now. (or should be)
49_chev: 1) I got the conversion kit from CPP. The instructions tell you to cut the rivets off your existing drum/hub and reuse the hub. I cannot find any rivets holding my hub to the drums. And when I lay the plate that comes with the kit on the drum, there are no holes where I'm supposed to bolt through.
2) New front axle. I took my axle to a shop to have the kingpins pushed out per instructions I received here "for $20". By the time he was done, he found that my old axle was junk. He found me a new axle that had already been rebuilt with new kingpins etc. That is now bolted to my truck. | | |
#63388 07/26/2006 5:13 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | 1.) If you have the CCP kit that let you keep the 6 bolt wheel pattern, Cletis would be able to "walk" you through the process as he did that conversion (be nice). I am assuming you have the half ton truck and NOT a 3/4 ton or larger. For some reason, I "think" you may have to enlarge the lower 2 holes in your spindle/steering arms. Ask somebody. I know when I did the CPP disk conversion, I went with the 5-bolt wheel pattern and the instructions said to enlarge the lower two holes. 1949 trucks had 7/16" +/- lower holes and the kit needed 1/2"+/- lower holes. I ended up using the spindles and steering arms from a 1954 (because I had them). I did not have to use the hubs as they were not needed for this particular disk brake conversion. My hubs were "well used". 2.) I was hoping you had actually found a NOS axle was why I asked.
#63389 07/27/2006 3:04 AM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | Thanks, 49_chevy.
I should be able to make it through the shoddy directions if I can just get my parts to cooperate. This darn 50 year old rust is really starting to get to me.
I can ask the shop that tracked down the axle for me, if you're looking for one. For the most part, I think it is NOS. But I have to warn you, it wasn't cheap.... I think I double the value of my truck with this axle. | | |
#63390 07/27/2006 5:49 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | wouldn't mind finding one of those axles either! | | |
#63391 07/28/2006 3:16 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hey D.G.
Cpp has a "how to" section that shows a step by step process. The written directions I got from them were generic but their online stuff was applicable. The hubs I'm dropping off will have the rivets already ground off. Do you want me to pop off the drums? I'd be glad to if that would help you out. Let me know....it'll lighten my load Tuesday!
Dave | | |
#63392 07/30/2006 12:41 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | RedGreen, You responded to a post a while back where your mechanic wanted to trash your axle because he wouldn't be able to put the retaining ring back in the knucle bore. 1950 3100 1/2-ton Pickups did not have "retaining rings". You may be having trouble finding those "rivets" on your hub because you may not have a 1/2 ton front axle.
#63393 07/30/2006 6:18 PM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | Fla54, I'd love it if you dropped off just the hubs. That would save me some work. Now that I have the front disks, I have no use for the drums. (I now have some huck drums piled up in my garage)
49_chev, I believe I have the original axle in there, but I could be wrong. I think my mechanic was wrong in his search for the retaining rings. I don't think it has any. In fact, the new axle he got for me doesn't have any. | | |
