5 members (Otto Skorzeny, Woogeroo, klhansen, 2-Ton, TUTS 59), 77 guests, and 6 robots.
Topics128,193
Posts1,057,241
Members48,465
Hello,
I'm searching for a '41-'46 stock rear end for my 1946 1/2 ton GMC. I suppose Chevy or GMC will do. Other than measuremensts, are there any part numbers stamped anywhere that would indicate the make and year of a rearend?
Thanks!
Here is some information about 1946 Chevrolet trucks. Maybe someone else will post info about GMC.
A 46 half ton would be an EC 101 or 102 depending on wheelbase. A 1940 AC through 1946 EC use the same axle housing.
The left hand flanged should be stamped 41. Right hand stamped 42. It would be a hypoid torque type. The carrier should be casting 3657339. 37 teeth on ring gear, 9 on pinion for 4.11.
