2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 12 New Guy | | New Guy Joined: Nov 2009 Posts: 12 | Hello,
I'm searching for a '41-'46 stock rear end for my 1946 1/2 ton GMC. I suppose Chevy or GMC will do. Other than measuremensts, are there any part numbers stamped anywhere that would indicate the make and year of a rearend?
Thanks! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | A 46 half ton would be an EC 101 or 102 depending on wheelbase. A 1940 AC through 1946 EC use the same axle housing. The left hand flanged should be stamped 41. Right hand stamped 42. It would be a hypoid torque type. The carrier should be casting 3657339. 37 teeth on ring gear, 9 on pinion for 4.11. | | |
