| | | Forums66 Topics128,048 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I purchased a replacement headlight knob. The picture showed it with the rod attached but I only got the knob. Apparently I only paid for the knob. I can either return it or if someone can tell me how to remove the old knob my rod is still functional. My old knob spins on the rod but I cannot see how to remove it short of a BFH and smashing it. There must be a better way. Can anyone enlighten me?
Chuck | | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | Pushbutton on side of switch housing under dash releases rod.
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I have the rod out. I want to replace the knob on the rod. Chuck | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd put the rod in a vice then heat it with a propane torch until the knob pulls off. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Tried heating the rod as you suggested Cletis. Came off quite easily. It seemed so obvious after you suggested it but it never occurred to me to try that approach. Thank you.
Chuck | | |
