2 members (Snowman51, Steelonsteel), 105 guests, and 2 robots.
Topics128,118
Posts1,056,646
Members48,450
#63361 07/23/2006 4:57 AM
I'm replacing my 216 in a 1949 Suburban with a 235. I'd like to keep the 216 look by using the 216 rocker and pushrod covers on the 235. Will they fit?
My rule of life: You can have anything you want; you just can't have everything you want.
#63362 07/23/2006 6:35 PM
This is supposed to be a common dressup trick. You will need the two long studs from the 216 and both sets of nuts.
1951 1 Ton Completed
#63363 07/23/2006 6:52 PM
Yes and No. The 216 pushrod cover will not work on a full pressure 235 engine. It is much shorter and doesn't go around the spark plugs. The valve cover can be used as described above.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#63364 07/23/2006 8:21 PM
I had to reread the question! I didn't even see the pushrod cover question, the first time around! Thanks Moneypit.
