| | | Forums66 Topics128,128 Posts1,056,664 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63361 07/23/2006 4:57 AM | Joined: Jun 2004 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 37 | I'm replacing my 216 in a 1949 Suburban with a 235. I'd like to keep the 216 look by using the 216 rocker and pushrod covers on the 235. Will they fit?
My rule of life: You can have anything you want; you just can't have everything you want.
#63362 07/23/2006 6:35 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This is supposed to be a common dressup trick. You will need the two long studs from the 216 and both sets of nuts. | | |
#63363 07/23/2006 6:52 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Yes and No. The 216 pushrod cover will not work on a full pressure 235 engine. It is much shorter and doesn't go around the spark plugs. The valve cover can be used as described above. | | |
#63364 07/23/2006 8:21 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had to reread the question! I didn't even see the pushrod cover question, the first time around! Thanks Moneypit. | | |
