| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | I'm switching from manual to power rack on my '49 , I did this same switch several years back on a '38 I had and got the pressure hose made up at the local NAPA , but now they can't seem to understand (or help) on what I need - a hose with the ford end for the rack and a chevy end for the pump .They keep asking me what year/model the rack is , I got it in a local salvage yard and it was not on a car , it is a ford and it bolts too my crossmember and the steering U-joint is for ford . Maybe a T-bird or ? but its NOT a pinto/must-II. what do I do for a hose now ? These guys used to be good about parts , now they just look at part numbers . | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | you go to a good engine builder and have a hose made
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | You can buy a ready-made hose kit with ford rack fittings and chevy pump fittings. Not sure if it fits T-Bird rack but worked great on my Mustang 2 setup. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | PS - remember to also get a " shim kit " to cut the pressure output of the Chevy pump down to Ford specs. | | |
