| | | Forums66 Topics128,204 Posts1,057,290 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Hello all, I did a very stupid thing and was hoping to get some advice from someone. I took both rear wheel cylinders apart to rebuild them, put everything in my parts washer to clean them and now I forget how they went together. I have a spring, 2 rubber cups, and 2 pistons. I am certain the spring goes in the center but what goes next, the cups or pistons? If it is the cups does the dished side or flat side go against the spring? If it is the piston is it the hollow side or the flat side that goes against the spring? I am looking for a very detailed response so I know I am putting this back together correctly. I know the metal caps with adjuster screws goes on last. Thanks in advance, Dave | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I take it you have new rubber cups. Put the spring in first then the cups one on each side with the lip faceing towards the spring. The pistons go in next with the flat against the flat of the cups. Clean the edge of the cyl & the metal cup. Free up the adj. screw & lube the screw & inner edge of the cup with silicne grease. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | You guys are great! I would have never put it together this way. I am so glad I asked and wasn't stubborn this time. Great advice and great website!!! | | |
