1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
RAK
Offline
Just got back from a little cruise.Truck started running rough and idle is higher,missing too I think,what could this be?Thanks
Vacuum leak, blew the carb out need to tune carb again, distributor slipped timing is off. Any more sdetails?
Larry
I don't own a vehicle that isn't old enough to drink.
RAK
Offline
I'll start checking those things,thanks.
If you're still running points and have a dwell meter you might want to do a check, or just check the point gap with a feeler gauge. Common problem with points, or if not used very often - either the points get pitted/burned or the rubbing block wears down, which changes both the dwell and the timing.
This doesn't usually cause the idle increase however, that is more likely a vacuum problem.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
RAK
Offline
yes, running points still.I am leaning towards a carb. issue.Thanks and I'll post the results.
RAK
Offline
Carb. needs to be rebuilt,that's the mechanic's conclusion.
