0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63308 07/21/2006 11:31 PM | Joined: Jun 2006 Posts: 96 Member | | Member Joined: Jun 2006 Posts: 96 | I'm not seeing where the factory assembly manual shows an intermediate u-joint on a 1949 3600. Maybe I'm looking in the wrong place. Anyway I split the intermediate u-joint to pull the driveshaft so I could replace the clutch. Reason for the clutch work is a serious chatter when starting from a stopped position. Especially in reverse. I found that the drive shaft has over an inch of play in the middle support. Is that supposed to be a snug fit there? If so then I'm thinking that could be causing the chatter. Still looking for a drawing of that middle driveshaft carrier. | | |
#63309 07/22/2006 12:25 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy leon2982, that is way to much movement, it should be snug but it should be able to move a bit, but not an inch. I'm with you on your theory that that may be causing the chatter. | | |
#63311 07/22/2006 5:25 AM | Joined: Jun 2006 Posts: 96 Member | | Member Joined: Jun 2006 Posts: 96 | So if I'm reading this right I'm missing some part(s) of the intermediate support bearing. On my driveshaft there is a ring, or race, and then then support bracket. I can fit my finger through the gap between the ring and the bracket. I'm looking for something that will show me what I need to buy to renew the intermediate bearing and/or mounting bracket. | | |
#63312 07/22/2006 5:53 AM | Joined: Jun 2006 Posts: 96 Member | | Member Joined: Jun 2006 Posts: 96 | Looks like I'm missing the intermediate support bearing and rubber cushion that fits inside the sleeve of the support bracket. It looks like Jim Carter has the bearing and cushion. Page 90 | | |
#63313 10/10/2006 5:44 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now if he only carried the u-joints for the 3600 we would be in business. Can't find them anywhere. Denny Graham Sandwich, IL
Denny G Sandwich, IL
