1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#63308 07/21/2006 11:31 PM
I'm not seeing where the factory assembly manual shows an intermediate u-joint on a 1949 3600. Maybe I'm looking in the wrong place. Anyway I split the intermediate u-joint to pull the driveshaft so I could replace the clutch. Reason for the clutch work is a serious chatter when starting from a stopped position. Especially in reverse. I found that the drive shaft has over an inch of play in the middle support. Is that supposed to be a snug fit there? If so then I'm thinking that could be causing the chatter. Still looking for a drawing of that middle driveshaft carrier.
http://www.leonmack.com/
'48 Chevy 1/2 ton
'66 Volvo 122S 2-door
'68 Volvo 220
3B Offline
Hy leon2982, that is way to much movement, it should be snug but it should be able to move a bit, but not an inch. I'm with you on your theory that that may be causing the chatter.
Propeller shafts and universal joints are listed here under rear axle.
http://chevy.tocmp.com/1948_51truckshop/51ctsm0450.htm
-Tom
1950 Chevy 3100 w/ 1956 235
So if I'm reading this right I'm missing some part(s) of the intermediate support bearing. On my driveshaft there is a ring, or race, and then then support bracket. I can fit my finger through the gap between the ring and the bracket. I'm looking for something that will show me what I need to buy to renew the intermediate bearing and/or mounting bracket.
'48 Chevy 1/2 ton
'68 Volvo 220
Looks like I'm missing the intermediate support bearing and rubber cushion that fits inside the sleeve of the support bracket. It looks like Jim Carter has the bearing and cushion.
Page 90
'48 Chevy 1/2 ton
'68 Volvo 220
Now if he only carried the u-joints for the 3600 we would be in business. Can't find them anywhere.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
