0 members (),
311
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63281 07/21/2006 3:06 AM | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Fairly new stovebolter. Replaced 216 in my '38 HC truck with 235 out of a 1954. You guessed it, the water pump shaft hits the radiator core. Fan? Fughetaboutit! I thought a 1954 235 was the ticket and would have correct pump/pully. When compared to the 216 pump, they seem to be almost the same size/depth. What did I overlook? I am not wild about relocating radiator forward as it looks like I could have an issue with the filler neck and the hood as I move forward. Maybe an electic "pusher" fan on the otherside of the core?? | | |
#63282 07/23/2006 12:31 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Just courious, are you sure you have a 54 engine? The fan to radiator clearance is close with a 54 engine but I have seen it done many times and work fine.
See the USA in your vintage Chevrolet! My Blog | | |
