0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63163 07/18/2006 1:37 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Does anyone know anything about the 4l60e trans?
Mine won't shift. | | |
#63164 08/10/2006 7:02 PM | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | do you mean 4L60E from a newer chev 98 and up | | |
#63165 08/10/2006 8:24 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | 95 corvette, I narrowed it down to the range pressure switch. Seems the 2nd gear sensor was stuck down. but after changing it it still won't shift. My pcm is being looked at again to make sure is not at fault. The pcm won't react to brake signal to unlock the tcc, so I think the pcm isn't telling the trans what to do. But until I hear back from them I can't do a thing. Just sit and look at it.
Bill | | |
#63166 08/14/2006 2:26 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | PCM came back and was ok. Now i'm really stumped. The vss is reading mph but I don't know if it's correct so maybe i'll change that. :confused: | | |
#63167 08/15/2006 2:29 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Lost! 2 mny abb. can't follow | | |
#63168 08/15/2006 1:49 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | PCM aka computer VSS.... vehicle speed sensor | | |
#63169 08/19/2006 7:30 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | All is good now. Turns out the dumb a@@ that wired it ( me ) forgot to wire the throttle postion sensor to the computer. The important one. Now the truck shifts perfect and the truck is offically on the road after 3 long yrs. not quite finished, but enough to enjoy it.
WOW, that vette motor has some power! Say goodbye to the rear tires! | | |
