1 members (59 fleet), 62 guests, and 9 robots.
Topics128,021
Posts1,055,353
Members48,420
#63163 07/18/2006 1:37 PM
Does anyone know anything about the 4l60e trans?
Mine won't shift.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#63164 08/10/2006 7:02 PM
do you mean 4L60E from a newer chev 98 and up
#63165 08/10/2006 8:24 PM
95 corvette, I narrowed it down to the range pressure switch. Seems the 2nd gear sensor was stuck down. but after changing it it still won't shift. My pcm is being looked at again to make sure is not at fault. The pcm won't react to brake signal to unlock the tcc, so I think the pcm isn't telling the trans what to do. But until I hear back from them I can't do a thing. Just sit and look at it.
#63166 08/14/2006 2:26 PM
PCM came back and was ok. Now i'm really stumped. The vss is reading mph but I don't know if it's correct so maybe i'll change that. :confused:
#63167 08/15/2006 2:29 AM
Lost! 2 mny abb. can't follow
#63168 08/15/2006 1:49 PM
PCM aka computer
VSS.... vehicle speed sensor
#63169 08/19/2006 7:30 PM
All is good now. Turns out the dumb a@@ that wired it ( me ) forgot to wire the throttle postion sensor to the computer. The important one.
Now the truck shifts perfect and the truck is offically on the road after 3 long yrs.
not quite finished, but enough to enjoy it.
WOW, that vette motor has some power! Say goodbye to the rear tires!
