Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (3B, Gdads51, 78buckshot, 1 invisible), 183 guests, and 5 robots.
Topics128,283
Posts1,058,512
Members48,490
#631516 03/23/2010 8:37 PM
Im working on my ignition and replacing pretty much everything.I went to put in the points and condensor and having a little trouble.I loosened the nut on the outside of the distributor that holds the wire from the coil,on the inside of the distributor where the condensor and points connect they will not come loose.I have pried on the stud to the point that im scared of breaking the plastic grommet.Am I missing some trick or is something else up?Never thought a set of points would hold me up lol.
Jeremy
581ton #631572 03/23/2010 11:22 PM
Jeremy,
I think if you look closely at the small stud with the nut removed you will see a small nut recessed in the plastic insulator. It will have two slots that require a special nut driver to loosen.
When you loosen that small nut, the attachment to the point spring will be released and you can change them out. Tim Lederman has info on that little nut...maybe he will see this and give us the hot ticket.
Stuart
atomarc #631582 03/24/2010 12:24 AM
I don't have the special tool so I use needle nose pliers on it.
581ton #631653 03/24/2010 3:28 AM
Thats what it was.I was going crazy with that thing.Thanks for the quick response and all the help.Seems that sometimes the simplest things give us the hardest times.Once again thanks guys.
Jeremy
581ton #632164 03/26/2010 12:42 AM
Anyone know where to get that tool at?Im definitaly going to put one of those in the glovebox.
Jeremy
581ton #632173 03/26/2010 1:07 AM
NAPA used to sell it.
You can make one out of a flat-blade screwdriver by putting a notch in the middle.
I'll look for a photo of the correct tool (or, I'll take a photo of one this weekend).
Thanks for the pics.Im gonna make a trip out and see if NAPA can get one for me,if not ill make one.
Jeremy
581ton #632956 03/28/2010 8:49 PM
+1 on the flat-tip screwdriver with a gap ground in the middle. Works like a champ, and only takes a couple of minutes with a cutoff wheel in a Dremel tool to make. I've also used a short piece of 1/4" steel fuel line with the end ground to fit the distributor nut.
