5 members (51sub, walter74, Gdads51, MickeyP, Chip O), 67 guests, and 2 robots.
Topics128,041
Posts1,055,593
#631253 03/22/2010 9:10 PM
Apprentice
Apprentice
1962 1/2 ton - Well, I read up on it, sounded easy enough... just remove the bolt and smack it a few times and POP out it comes! I don't Think so, I spent a good hour hamming away with a 2lb. hammer and NO LUCK! The uppers popped loose pretty easy. I'm trying not to use a Pickle Fork because the ball joints are fine and I don't want to spend $189 ea. to replace them (by tearing up the boots) - just trying to put on my new spindles. DOES ANYBODY HAVE A GOOD METHOD OF GETTING THE LOWER BALL JOINT TO BREAK LOOSE? I have no torch , so I can't really put heat to it.
They always come apart easy on paper. Do you have a Pickle Fork?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Apprentice
Apprentice
YES!, But trying not to use it - don't want to destroy the boot!! New Ball Joint are About $145-189 each :-(
Apprentice
Apprentice
Well, I used the Ball joint Pickle Fork (put grease on the fork and it didn't rip the boot) and with a couple good smacks it broke loose!!! (LOWER BALL JOINT) Great news, but when I put on the new spindle and started tightening the nut - the ball joint stud rotates with the nut... Does this mean the ball joints Broken, or do I need to compress the spindle on the shaft a bit first? Not really a Ball joint Guy, I don't know exactly what kind of motion is OK.
You can use a large pair of Channel Lock pliers to apply pressure to the spindle and balljoint housing. get the nut started and run down as far as possible. I would advise using an impact to get it run down quicker, just don't hammer on it too hard, do the final tightening with a torque wrench.
Bill Burmeister
