6 members (klhansen, Tom McGrath, Shaffer's1950, David Bush, Hotrod Lincoln, JW51), 82 guests, and 0 robots.
Topics128,051
Posts1,055,735
#63118 07/17/2006 6:08 PM
I have '58 chevy V8 (actually I'm doing a conversion from a 235-6 to a 283 using original type mounts, bellhousing etc.) Does anyone know what year flywheels will work with this application? I want to make sure it will work with my bellhousing mounted starter. Also, I'm looking for a flywheel for 10" or 11" clutch if anybody has a good one for sale that will work with my application.
My other question is about balancing. If I pick up a flywheel to use on my 283, what should be done as far as balancing?
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
#63119 07/17/2006 6:45 PM
Old Gold,
In regards to the flywheel balance question, I was under the impression that each and every flywheel was balanced to itself. If you find a flywheel that fits your application, bolt it on and it should be fine.
I have seen race motor cranks balanced with the flywheel (and maybe clutch too) attached, but I don't think this is necessary for everyday use.
Stuart
Stuart
#63120 07/17/2006 8:05 PM
about any standard trans smallblock flywheel from 55 on that takes an 11" clutch [truck] will work - there's a car bellhouse and flywheel that's smaller and mount the starter different, and that's for a 10"
for the balance, as above - if you get it surfaced at a machine shop they'll check the balance, otherwise it's not a worry
