7 members (baldeagle, Hush, mick53, Southerntruck, SmalltownTRKGuy, Hotrod Lincoln, Gray_Ghost),
102
15
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 7 New Guy | | New Guy Joined: May 2009 Posts: 7 | Hi everybody,
We're about to start working on my 57 Cab, and like all of you, I've ordered over the past 6 months a bunch of catalog. But going through Classic Parts catalog, I've realized that they have two different kind of cab corners - the only description is "Left" or "Left Deluxe" (same thing for the right side). There's also $50 difference between the two of them. Does anybody knows if that refers to "quality" of if there's realy a difference between regular and deluxe cab? When I've looked on some other supplier's web site, they offer only one. Since I already bought them, I'd rather know right away if I bought the right stuff.
Thanks guys. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sometimes there is just a little rust in the lower corner and sometimes the corner was full of leaves and mud for 50years and the entire corner is rotted away. My guess would be that it has to do with the amount of rust your dealing with. That is, one takes up more terratory than the other. Best to call the vendor and ask them, alway better to hear it straight from the Horse's mouth. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Deluxe is probably inner and outer panels.... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Since the standard and deluxe panels are the same dimensions, 1958GMCnut is probably correct. Denny's suggestion, however, is the prudent approach, especially since the phone call is free: 1-800-741-1678
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I wondered if the deluxe version had a drain stamped in them,the 'cheaper' ones I bought dont. Then I thought a $50 premium seemed a bit high for stamping a drain hole! I think 1958GMCnut is probably nearer the mark as well. As the guys say...give them a call! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2009 Posts: 7 New Guy | | New Guy Joined: May 2009 Posts: 7 | Thanks guys! I was just wondering if any of you may have ordered one of them. I'll give them a ring tomorrow.
Thanks guys! | | |
