5 members (Hotrod Lincoln, Gray_Ghost, 78buckshot, Pete O, 1 invisible), 309 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
#630034 03/18/2010 6:29 PM
Big Bolt Forum Co-moderator
I may purchase new tires for my 1948 two ton. What are the advantages of either? I am going to start pricing today, so if one is cheaper by a lot, that might be a deciding factor, but I would have to know what I am giving up or getting an advantage if I go smaller or bigger?
1948 Chevy 2-Ton
there's not a lot of difference between those sizes except that the 8.25s will be more available with more choices, and likely a bit cheaper as a result - there will be a fractional improvement in mpg and speed per rpm - watch that the fronts don't rub enough on hard turns that problems develop long term .... the 8.25s worked fine on my 46 but did rub at full lock
V
V Offline
If I remember it correctly, the 7.50's go on the front and the 8.25's on the rears. You can see the diference in the front but I haven't had a problem with 8.25's all around on my firetruck.
I couldn't find radial 7.50x20's when I was hunting tires a few years ago.
make sure that if you are going from 7.50 to 8.25 that the duals don' touch together....
I have a qoute from ITC in langley for steer tires 8.25 x 20"
for $196.00...don't know what make though...
Dave
GMC: Get More Cash...
1958 GMC
My Webshots photos
i run 7.50s on the front and 8.25s on the rear on my 6100 dump. the ashton has 8.25's all around. no issues with either truck. i also know a guy who is ruuning 9.00's all around on his 6400 firetruck. small gap between the tire and fender on the rear and the front rub at full turn.
Hey All,
On my '53 6100 I am running 8.25-20 on the front and 9.00-20 on the rear and I don't have any problems with "steer rub".
I know it sounds like some sort of ointment. grin
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Yeah... steer rub sounds like a marinade for steaks. All the originals on my truck are 8.25 X 20. They were steering on the front, and traction on the back, but I will most likely put steering all around.
1948 Chevy 2-Ton
Yeah, got mine with the truck,nice big lugs for traction on the rear.You can look at my 'bucket' page and see what they look like.
Jeff
1953 Chevy Two-Ton
V
V Offline
Mine actually rube if you go "stop to stop" on the outer frame. Not a big deal as long as you remember not to cut the wheels all the way.
Dang I emailed Nebraska Tire over two weeks ago and still haven't heard back from them. I don't like it much when a company has an email and doesn't answer. One of the major AD truck parts guys is the same way. You have to call them if you want an answer.
1948 Chevy 2-Ton
Super55, go here to look at Denman tires. Very nice style selections and a wide range of sizes. Prices are reasonable and include both flaps and tubes.
Denman Tires
Denman has a good reputation.
Have 8.25 x 20 on my 1948 GMC 3 ton, front and rear, no issues with front tire rub, plenty of space between rear tires.
Billyray
1948 GMC 3 Ton Flatbed
1952 Chevy 1/2 Ton Panel
1956 Chevy 3/4 Ton NAPCO
I found the local truck tire store to have a nice stock of 9.00x20's used with 75% tread life left...they only wanted $50 each for what is an essentially new tire. running 9.00 on front (NO RUB AT ALL) and 8.25 on back. it leveled out the truck w/out any suspension mods. all said and done, $145 for two fronts and two new tubes.
