0 members (),
299
8
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I may purchase new tires for my 1948 two ton. What are the advantages of either? I am going to start pricing today, so if one is cheaper by a lot, that might be a deciding factor, but I would have to know what I am giving up or getting an advantage if I go smaller or bigger? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there's not a lot of difference between those sizes except that the 8.25s will be more available with more choices, and likely a bit cheaper as a result - there will be a fractional improvement in mpg and speed per rpm - watch that the fronts don't rub enough on hard turns that problems develop long term .... the 8.25s worked fine on my 46 but did rub at full lock
Bill | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | If I remember it correctly, the 7.50's go on the front and the 8.25's on the rears. You can see the diference in the front but I haven't had a problem with 8.25's all around on my firetruck.
I couldn't find radial 7.50x20's when I was hunting tires a few years ago. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | make sure that if you are going from 7.50 to 8.25 that the duals don' touch together....
I have a qoute from ITC in langley for steer tires 8.25 x 20"
for $196.00...don't know what make though...
Dave | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i run 7.50s on the front and 8.25s on the rear on my 6100 dump. the ashton has 8.25's all around. no issues with either truck. i also know a guy who is ruuning 9.00's all around on his 6400 firetruck. small gap between the tire and fender on the rear and the front rub at full turn. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Hey All, On my '53 6100 I am running 8.25-20 on the front and 9.00-20 on the rear and I don't have any problems with "steer rub". I know it sounds like some sort of ointment.
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Yeah... steer rub sounds like a marinade for steaks. All the originals on my truck are 8.25 X 20. They were steering on the front, and traction on the back, but I will most likely put steering all around. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Yeah, got mine with the truck,nice big lugs for traction on the rear.You can look at my 'bucket' page and see what they look like. Jeff | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Mine actually rube if you go "stop to stop" on the outer frame. Not a big deal as long as you remember not to cut the wheels all the way. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Dang I emailed Nebraska Tire over two weeks ago and still haven't heard back from them. I don't like it much when a company has an email and doesn't answer. One of the major AD truck parts guys is the same way. You have to call them if you want an answer. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2010 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 112 | Super55, go here to look at Denman tires. Very nice style selections and a wide range of sizes. Prices are reasonable and include both flaps and tubes. Denman TiresDenman has a good reputation. Have 8.25 x 20 on my 1948 GMC 3 ton, front and rear, no issues with front tire rub, plenty of space between rear tires. Billyray
1948 GMC 3 Ton Flatbed 1952 Chevy 1/2 Ton Panel 1956 Chevy 3/4 Ton NAPCO
| | | | | Joined: Feb 2010 Posts: 7 New Guy | | New Guy Joined: Feb 2010 Posts: 7 | I found the local truck tire store to have a nice stock of 9.00x20's used with 75% tread life left...they only wanted $50 each for what is an essentially new tire. running 9.00 on front (NO RUB AT ALL) and 8.25 on back. it leveled out the truck w/out any suspension mods. all said and done, $145 for two fronts and two new tubes. | | |
