0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 26 New Guy | | New Guy Joined: Mar 2010 Posts: 26 | have pressed out all the tie rod ends and ordered all new ends from classic, they all fit but the pitman arm off the steeing rod. hole is to small. noticed this when pushing them out that they were different sizes. can i just drill this hole bigger? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I see you have a 1951 pick-up what model 3100,3600,3800 there are differences. Call me I am in Utah as well 801-831-4838. | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | It depends on how much you need to drill out. A little should be OK, I wouldn't want to double the size of the hole!
Joe | | |
