| | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62977 07/11/2006 7:03 PM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Will the H/W carbs listed for sale on Langdons ( http://www.stoveboltengineco.com) work as a replacement for a Rochester B on a 235 engine with manual choke? Thanks, Steve
Today is the best day of my life!!!
#62978 07/11/2006 9:35 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Steve, the best person to ask this question is Tom Langdon himself. He's a wealth of information. I don't see why they can't be used but the ones I got were automatic choke (electric and water heated). I put mine on a Offy manifold but you would need the carb adapter to go from two BBl's to one BBL manifold. http://community.webshots.com/user/geezer | | |
#62979 07/11/2006 11:10 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Steve,
I just ordered a H/Wcarb/adaptor/linkage/air cleaner/electric choke conversion from Tom yesterday to fit on my 56-235 in a 54 truck. I had originally wanted a Carter Weber but he explained that for a single replacement the H/Weber was the correct item. It seems that the Carter Weber carbs are more suited to work in pairs on an aftermarket intake. This carb is a Holley Weber 5200 (used on a variety of 80's engines) remanufactured with a good track record. His price on the unit is cheaper than any I've seen and there is a wealth of info on applications and tuning on the net.
However, the carb comes with a water heated choke but for an extra $12. you can get a kit to convert it to electric. From my reading the 12v electric choke works great. You'd just have to run a 12v power source to the choke in place of your choke cable.
I haven't heard any negative comments on the adaptor or the carb and most proclaim an increase in performance and mileage with this setup.
Hope this helps. | | |
#62980 07/12/2006 12:25 AM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks to both for the help. I will send Tom an e-mail.
#62981 07/16/2006 4:12 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I have the Holley Webers and if I had a choice I'd try to use a manual choke the next time. The electric are difficult to adjust and don't work in unison IMO. | | |
