0 members (), 40 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#62977 07/11/2006 7:03 PM
Will the H/W carbs listed for sale on Langdons (http://www.stoveboltengineco.com) work as a replacement for a Rochester B on a 235 engine with manual choke?
Thanks, Steve
Today is the best day of my life!!!
#62978 07/11/2006 9:35 PM
Steve, the best person to ask this question is Tom Langdon himself. He's a wealth of information. I don't see why they can't be used but the ones I got were automatic choke (electric and water heated). I put mine on a Offy manifold but you would need the carb adapter to go from two BBl's to one BBL manifold.
http://community.webshots.com/user/geezer
Country Roads, West (By God) Virginia
#62979 07/11/2006 11:10 PM
Steve,
I just ordered a H/Wcarb/adaptor/linkage/air cleaner/electric choke conversion from Tom yesterday to fit on my 56-235 in a 54 truck. I had originally wanted a Carter Weber but he explained that for a single replacement the H/Weber was the correct item. It seems that the Carter Weber carbs are more suited to work in pairs on an aftermarket intake.
This carb is a Holley Weber 5200 (used on a variety of 80's engines) remanufactured with a good track record. His price on the unit is cheaper than any I've seen and there is a wealth of info on applications and tuning on the net.
However, the carb comes with a water heated choke but for an extra $12. you can get a kit to convert it to electric. From my reading the 12v electric choke works great. You'd just have to run a 12v power source to the choke in place of your choke cable.
I haven't heard any negative comments on the adaptor or the carb and most proclaim an increase in performance and mileage with this setup.
Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#62980 07/12/2006 12:25 AM
Thanks to both for the help. I will send Tom an e-mail.
#62981 07/16/2006 4:12 PM
I have the Holley Webers and if I had a choice I'd try to use a manual choke the next time. The electric are difficult to adjust and don't work in unison IMO.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
