| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 105 | On the AD trucks was the underside of the hood painted the same color as the rest of the truck?
Thanks!
Chris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | All of the AD trucks that I've been under to hood of had flat black on the underside of the hood.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Undercoat black with body-color over (under) spray.
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Agreed. Mine is a black primer looking finish. It even has written in grease pencil on the underside a script "transport" that I assume is due to the transport blue paint color. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Same here, black e-coat like primer some signs of the body color overspray around the edges. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2008 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 105 | Thanks!!! That info helps alot. I have been trying to determine what the original color of the truck might have been. I am discovering more and more evidence that it is Mariner Blue.
Chris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Agreed. Mine is a black primer looking finish. It even has written in grease pencil on the underside a script "transport" that I assume is due to the transport blue paint color. My '55 also has grease pencil marking under the hood as well, C Blue, which I beleive is Crystal Blue. I've seen similar marking on other trucks as well.
