1 members (1 invisible),
105
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62926 07/10/2006 8:00 PM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | In the Task Force era GMC and Chevy 1/2 ton trucks, are the front crossmembers the same?
I want to mount a period correct 283-V8 in my GMC chassis using the original type chevy front mounts, but then it occurred to me that the GMC motors were longer than the chevy and that the front crossmember may be different. I'm pretty sure that was the case on earlier year trucks anyway. Does anybody know for sure about the TF trucks?
Red58? You're very knowledgeable, any idea?
I have a '58 Chevy and a '58 GMC, but unfortunately they are not both in the same location so I can't compare them side by side.
Thanks. | | |
#62927 07/10/2006 9:34 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The frames should be the same. The difference is in the mounts that are bolted to the engine. You should be able to use the v-8 kit for a Chevy with no problems.
Bill Burmeister | | |
#62928 07/12/2006 12:42 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | gmc crossmembers were completely different than chevies. The 6 and 8 cylinders used the same crossmember. there was an extra plate riveted to the v-8 crossmember for an engine mount. I believe the gmc 8 mounted under the balancer to the crossmember. you can swap crossmembers by drilling out the rivets. Even with the gmc crossmember, it should be a pretty straight forward swap. blue chip crossmembers are the same for 55-57 and 58-59. the 58 and 59 are eazier to swap because the radiator and front sheet metal do not mount to the crossmember like they did in 55-57 models. | | |
#62929 07/12/2006 4:24 PM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | OK...it looks like I'm in for a crossmember swap. With patience and a big hammer, I'm sure I can get 'er done. Thanks bigbad. I looked at the GMC crossmember yesterday and it looked different that I remember the Chevy crossmember being.
Are the Chevy 6 and 8 cylinder crossmembers the same? Or do they have extra plate riveted on as well? | | |
#62930 07/15/2006 2:49 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I think the chevy crossmembers are the same for 55-59. Don't know for sure... never had a chevy. I thought the chevy used the donut mount and had two sets of holes, the closer set for the 6 cylinder, and the wider set for the v-8. Don't know for sure.
Only know about the gmc crossmembers because somebody had welded a chevy one in to my gmc chasis and put a chevy 235 in there. I had to locate a 58-9 gmc crossmember, and I had to cut the chevy crossmember in pieces to get it out. All that for a truck I ended up getting rid of before I put the 302 gmc in it!
I really don't think you need to swap crossmembers. I think you could probably set the engine in there and drill the holes where you need them in the gmc crossmember. my .02
Getting the crossmember out is the easy part. Trying to get it back in is the hard part.
If you do go for the swap, Get a lot of patience, a big hammer, and a couple heavy duty ratchet tie downs. The frame has a tendency to open up just enough so the rivets or bolts won't line back up. Good Luck!
John | | |
#62931 07/15/2006 5:14 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes the Chev cross member is the same for 6 and v8, except if it had a v8 then there were 2 brackets riveted to the back of the cross member to mount the v8 [cuz shorter than the 235] - the kits available from the vendors that's called 'original style' v8 mounts includes the frame brackets that you bolt on [rivet holes should be present], along with the pegs and small brackets that bolt to the front of a small block - you'll also need a fan shroud or it'll overheat at low speed cuz the fan's too far back
and yes, I think the cross members are too different to work installing a 283 the same way in a GMC - you could use whatever the GMC v8 was for 58 tho!!
Bill | | |
