1 members (Forty9), 66 guests, and 1 robot.
Topics128,055
Posts1,055,782
#628867 03/14/2010 9:03 PM
I drove down the road in the 59 Apache , turned around at the heighbors and came home. I have rebuit the original one barrel carb, changed plugs, coil, battery, master cylinder. Engine sounds fine and first and second gear are good. Once shifted into 3rd it hesitates alot and stalls.Starts back up fine. Could this be a choke issue since I do need to have it partially choked?
Thank you for your help.
Steve
MREDWARD #628875 03/14/2010 9:28 PM
Riding in the Passing Lane
Sounds like it's starving for gas. Stopped up fuel line or filter or weak fuel pump. If that's not it the float level may be too low or the power valve not working.
1972 Chevy c10 Cheyenne Super
