3 members (2-Ton, 1955 1 Series, Phak1), 126 guests, and 2 robots.
Topics128,091
Posts1,056,449
Members48,443
Does anyone have an opinion on installing A/C on the old style low pressure 235?
I'm wondering if the 95 hp can handle it?
I'm assuming that you would turn off the compressor on hills and on fast acceleration (getting on expressway).
I ran an A/C with a Sanden compressor on my 216 for several years and never had any engine power issues.
Its not the HP you have to worry about, its the cooling. If your radiator is in good shape the engine will pull it. Patricks has sold a kit for the installation for about 20 years.
When I was younger my neighbor got a new 56, 6cyl 235 auto with air, when he would turn it on it would loose about 5 mph on flat ground. But today we have more compact compresors with a lot less drag.
You Learn more Listening than Talking
How do you handle the drop in idle speed when it comes on?
1951 1 Ton Completed
you install an idle up solenoid. take one off a newer engine and wire it to the a/c compressor clutch hot wire. it manually moves the throttle linkage @ carburator; mounts to the carburator as well
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
Thanks, I was wondering how that was taken care of.
