5 members (KEVINSKI, FAST55, Hanks custodian, Otto Skorzeny, Rusted Nut), 66 guests, and 6 robots.
Topics128,075
Posts1,056,007
Members48,433
I have a c10 short bed with a straight shift & 350 engine. I want to change over to automatic and would like to see a picture of the chassis differences.
1. do I use the same crossmember but move it?
2.will I need a new bellhousing?
3.will I need a different driveshaft?
4. any suggestions as to type of tranny?
Thanks Don [email protected]
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
You will have to cut out the crossmember for the stick & use an automatic crossmember(I have one for sale grin )
The automatic has the bell housing built on.
Most likely unless you happen to get the tansmission and drive shaft from a truck of the same lenght.
You could run a 350 turbo, 400 turbo, 700R4 or later model overdrive transmission
