1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I am working on a master cylinder conversion on my 1940 GMC 3/4 ton. I will be using the brake and clutch pedals from a big bolt, and then use a frame mount 2 chamber MC.
The brake pedal I am using has a rod and clevis attached to it that pulls a frame mounted lever, when the brake pedal is pushed. The frame mounted MC is then actuated by the same lever in a pushing motion. I am trying to locate on the frame where that lever bracket should be. My truck doesn't have any of the holes in the frame as it was not originally equipped with this setup. Can somebody give me a measurement from the back vertical edge of the bellhousing crossmember to the first rivot of the frame mounted lever?
Thanks in advance John | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The measurement should be the same for chevy and gmc trucks from 1939-1946. Thanks John | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | bump
I just got the Master cylinder. Some measurements would be really nice so I no where to put it. Please Help if you can.
John | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hi BBSD,
I think readers are slow to give you info because it is probably different across the board especially when you leave the 1/2 ton size, and use different pedals etc. This is a fabrication type deal which means everyone will probably do it a little differently. Mount the pedals, then if you have a rod, there is your measurement. If not, then mount the MS to the frame in a convenient location, within a reasonable distance from the pedal and make, find, buy an adjustable rod. I haven't done this yet on this year of truck, but will be on a 2 ton. I'm not concerned about mounting location. I'll be focused on the rod length when I'm done mounting things up. Just my two cents.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I guess your advise is sound. I was trying to stick close to the stock geometry. Since I am using factory pedals, factory bellhousing, and crossmembers, I figured I would put these things where the factory did. I can guess where they should go, but as my cab is not on my truck at the moment, I will have no way to reference where the pedal should be.
I am asking for a simple measurement, but apparently there is too much snow still on the ground.
Thanks | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | my 38 1.5 has the same set up it sounds like you are describing. i notice you cut it at 39. do you think 38 would be different? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Probably not, but the crossmember might be different. I'll take the measurement anyway if you are willing to give it to me. The rod that goes from my pedal is about 23 inches from center to center of the holes, or 24 inches overall. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | i'll see about the measurements later today | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | The rod from brake pedal to the lever on my 38 is also approximately 24". distance from back of bell housing to the first rivet appears to be 20 1/2". top of lever bracket is about 3/4" from inner top edge of frame rail
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Thank you! That measurement looks pretty good on this end. | | |
