0 members (),
155
Mod | | | Forums66 Topics128,167 Posts1,057,018 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 64 | hello - i would like to increase capacity on my 59 6 cyl fleetside 1/2T 4sp. compound. could i just add a special heavier spring to my current set up (and if so what spring ought i get ?) or might it be better to replace the rear with a 3/4 T rear end with springs? thanks paul | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Why do you want to increase the capacity? How do you plan to use the truck?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | 3/4 ton springs will fit your truck. I have the extra heavy duty 10 leaf springs (optional for 3/4 ton) in mine. Beware you'll still only have half ton brakes, though.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Sep 2006 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 64 | ed - thanks for the heads up about the brakes. do you know what is the exact difference in the 3/4 T brakes is ?
if i go the 3/4 T route should i get the 3/4 T reseviour and other assembly off of the 3600 ? currently the brakes are stock on my 1/2 T fleetside. sounds like i just answered my own ? if the 3/4 brake stuff is beefier. thanks paul
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | You still haven't answered how you are going to use the truck.
My 1959 1/2 ton longbed gmc has a set of helper springs, or overload springs on it. It also has air shocks. You could increase load carrying capacity in those simple ways. There is also a load handeling air bag available that can help carry a load.
As stated above if you want to carry more weight, it is important to be able to stop more weight. A disc brake setup on the front will help. The rear only accounts for about 15% of the total braking. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | In addition, if you only swapped the rear brakes to 3/4 ton, which would also require swapping the rear axle, you would end up with a brake system with poor porformance, as the front and rear balance will be upset. As far as springs go, 3/4 ton springs were a factory option on the '55-'59 trucks. My '55 3200 has 3/4 ton springs on the rear.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 64 | hello bigbaddaddy- thanks for replying. just trying to think out my options. i have had airbags and while they are a low cost easy option i have found they donot last long. steel lasts. disc are in the future but not now. i can obtain 3/4 t stuff relatively easy. do you know if the 3/4 t brake system is beefier than the 1/2 t ? as to what i will haul ! mostly non commercial stuff. you know like home and recreational stuff.  paul | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 3/4 ton brakes are beefier/larger, but swapping them will require swapping the entire brake system. The master cylinder itself is the only common part. The rear brakes will require swapping the entire axle, fronts will require at least a spindle and bearing swap. The hard lines will also have to be changed out as 3/4 ton uses larger steel lines. You will also find that the rear gear ratio is not highway freindly at 4.56 (std) or 5.13 (opt). Plus the wheels and tires will have to swapped due to the different bolt pattern.
Bill Burmeister | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Paul - changing your truck to a 3/4T for hauling average "home and recreational stuff" is wasted effort, unless you're building the home and playground  if a reasonable load has it draggin it's butt you need some new springs I regularly haul up to a ton of apples in my long fleet 1/2T with original overloads and the short step carries well over 1/2T with just good original suspension - mind you that's not on highways and the steering does get a little light  Bill | | | | | Joined: Sep 2006 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 64 | sounds like i will look into adding a helper spring to the 1/2 T. and focus now on optimizeing the stock brake system. thanks for all the good advice. paul | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Good plan. Brake upgrades are much easier to come by for 1/2 tons than 3/4tons. Just saw an article about 13" front disks for a 60's 1/2T. 3/4ton it's roll your own!
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
