2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62833 07/10/2006 12:38 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | I,m putting a stick behind my 56 Chevy 235 engine and I have a chance to buy a Truck one with the flywheel, clutch,etc. but I want to be sure it will fit. And will the rear side mounts be the same as a car? Help??? Thanks | | |
#62834 07/10/2006 1:35 AM | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | The flywheel and the clutch are the same for the car and truck but the truck bellhousing mounts on pads on the crossmember. The car has frame horns and the mounts are on the sides of the bellhousing. Fred
#62835 07/11/2006 1:16 PM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | Thanks Fred. Do you think it can be made to work in a car with alittle work? | | |
#62836 07/11/2006 3:14 PM | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I'm not sure as the mounts are different and in different locations. Some of the suppliers like Danchuk and CCI have a special trans side mount that attaches to the frame horns but it is primarily for late automatics when using the original front mounts and the tail shaft mount. It is for extra support. You might take a look at it. You could possibly take out the frame horns and install a crossmember. However, it would be a lot of fabrication to do for a stock application. Fred
