0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62825 07/09/2006 11:12 PM | Joined: Aug 2001 Posts: 23 New Guy | | New Guy Joined: Aug 2001 Posts: 23 | I just redid my clutch in the 49 and found I can not get a replacement low profile clutch anymore. The clutch is a 11" on a 261 fits ok with a short throw out but I only have about a 1/16" clear on the high side of the bell housing. I think I'm ok but would like some of your input
sader dog
#62826 07/10/2006 12:28 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy saderdog, ever heard the saying "a miss is as good as a mile". But seriously start the engine and make a few shifts and listen | | |
#62827 07/10/2006 5:07 PM | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | I am running an 11 inch clutch behind my 261. It is tight. In fact when installing it the pressure plate rubs against the bell housing while you are tightening it up but once it is torqued down it works fine. I have put thousands of miles and a number of trips down the drag strip without a problem. I assume you must have the flywheel drilled for the 11 inch clutch and if so it should work fine. | | |
#62828 07/11/2006 11:54 AM | Joined: Aug 2001 Posts: 23 New Guy | | New Guy Joined: Aug 2001 Posts: 23 | thanks for your input, I think I will go on and run it, but Jim Carter has a thin pressure plate that I am going to get and have in my backup stock. the clutchs are getting hard to come by
sader dog
