1 members (TooMany2count), 119 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
Guys, I have a 62 c30 and I've been doing some reading, on the 60-66 year the c10 and c20, they can swap the front crossmember from 1973-1987 to gain the disk brake setup.
Need some brain storming, could we possibly do the same thing on the c30? providing the 73-87 donor truck is one ton as well (3500 series?)
Thank you,
Danny
I've seen a '61 C30 taken apart and the front suspension did not look any different than any of the lighter ones I've seen.
I don't believe the swap is quite as simple when converting from torsion bar, but it can be done.
Thank you, and I would guess 63-64 would be a little easier swap, eh?
Thank you again, now I can add one more item on "the things to do list" smile
Torsion or no torsion that would be the question.
Danny
Let me start by saying I haven't done my swap yet.
I have a 61 C30 panel truck.
I bought a 67 C20 drum brake crossmember assembly.
(actually I have the entire front half of a C20 pickup frame so I know where the steering box and idler arm go.)
The torsion bars go away if you swap in a more modern front suspension and then the torsion bar crossmember can go too.
The 3/4 and 1 tons have a more normal looking ladder frame, no X member. Makes it simpler to work on I think.
Pete
Moderated by  Dusty53
