0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | i have removed all the bolts i can see. I have notice two pegs one the bell housing, one on each side, and i am not sure if these are just guides or they have to be removed. Also, do i nedd to remove the oil pan. i have the engine mounts removed.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The two pegs shouldn't have to be removed. I've pulled the 292 out of my 63 C20 a few times without removing pegs or oil pan.
Has the truck been a runner till now?
Is it not wanting move away from the bell housing?
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Every engine I have pulled the dowel pins or pegs are guides. Sometimes it takes a little persuasion to seperate the engine from the bell housing.
The last engine I pulled, a 350, I gently used a crow bar. The problem in this case was one side wanted to come off easy putting the engine and bell housing in a bind. I reinstalled a couple of the bolts to bring the whole assy. back together and then made sure both sides came back apart equally. | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | mine seems to be doing that, i will try installing the bolts again and remove quickly and evenly.
thanks
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | iron clad has some good advice. prob the clutch and the tranny sprine is in a bind. sometimes puting one in is almost as much fun. good luck! | | |
