1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
i have removed all the bolts i can see. I have notice two pegs one the bell housing, one on each side, and i am not sure if these are just guides or they have to be removed. Also, do i nedd to remove the oil pan. i have the engine mounts removed.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
The two pegs shouldn't have to be removed. I've pulled the 292 out of my 63 C20 a few times without removing pegs or oil pan.
Has the truck been a runner till now?
Is it not wanting move away from the bell housing?
Larry
I don't own a vehicle that isn't old enough to drink.
I
I Offline
Every engine I have pulled the dowel pins or pegs are guides. Sometimes it takes a little persuasion to seperate the engine from the bell housing.
The last engine I pulled, a 350, I gently used a crow bar. The problem in this case was one side wanted to come off easy putting the engine and bell housing in a bind. I reinstalled a couple of the bolts to bring the whole assy. back together and then made sure both sides came back apart equally.
mine seems to be doing that, i will try installing the bolts again and remove quickly and evenly.
thanks
iron clad has some good advice. prob the clutch and the tranny sprine is in a bind. sometimes puting one in is almost as much fun. good luck!
