2 members (Bill Hanlon, Lightholder's Dad), 118 guests, and 1 robot.
Topics128,131
Posts1,056,724
Members48,454
On my '58 I'm doing a 6 cylinder to 283 V8 conversion and I'm keeping the same trans. I have a 55-59 V8 bellhousing but I'm looking for the correct flywheel. I believe the original would take a 10" clutch, is that correct? Is a passenger car flywheel the same as 1/2 ton pickup? Anyone know what interchanges? What about tooth count?
Any help would be greatly appreciated.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
I'm sure there were different ones offered, like 10, 10.5 and 11, and yes, the car and truck should interchange if both had standard trans - someone might have a parts book to say for sure, but I think the flywheel will be the same up into the 350 years, and the starters are all interchangeable, so teeth will be the same
Thanks Bill, I have an opportunity to pick up a flywheel. The fellow has two, one for an 11" clutch and one for a 10.5". Does anyone know, will an 11" clutch fit with my factory bellhousing, clutch fork, etc.? Or does it make a difference. I'd like to go with the 11" if it will clear everything.
Chevy Duty lists clutches but only 10" or 11", no 10.5". hmmmm...
I just found out that the 10"" clutch was usually used with my 3 spd, Is there any reason why I couldn't go with the 11"?
Mike
I've always run an 11 inch clutch on my trucks;there's plenty of room for the lower bolts.The 11 incher has been available for a long time in pretty near all GM's cars and trucks,and for my money it's worthwhile to go with the biggest clutch I can get.(I know-it's overkill,but if it makes the difference between having enough grip or not,even once,it's paid for itself.) BTW-my parts man tells me an LUK 12" diaphragm clutch will fit anywhere an 11" will,and is less money. The part # he gave me is 04-064.$148.13-Complete kit. Might be worth a look.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
the red58 has an 11", all works fine - throwout fork is the same for all, as is bellhouse
Thanks you guys! I've certainly received a lot of help here is the last few days. I sure appreciate it.
rfs58trk (Fred), a check is in the mail to you for that clutch fork. Thanks again for your help. I may be calling you again sometime for more advice as long as you don't mind.
Mike
