| | | Forums66 Topics128,091 Posts1,056,445 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Quick and simple:
Will charging my 6 volt battery on a 12 volt charger fry it?
Any idea of how to test if the battery charger is working? It's the type with no settings, just on or off.
Thanks! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Don't do it. Get an electrical multi-tester to check your charger to see if it works, but still don't put 12v charge on a 6v battery. It will ruin it and possibly violently. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Invest in a battery charger that will do both (Harbor Frieght) sells one at a decent price that I have had good luck with. Buy one with the amp gauge on it the gauge will tell you if it needs a charge or when it is charged. Sears sells similar models for around $100 cheap when you consider what blowing one up might cost. Cautionary tale my neighbor years ago hooked one up no safety glasses, sparked, battery blew up in his face and he eventually lost one eye. Be careful, use good equipment and follow safe practices they can be very dangerous. | | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Thanks, I have a charger for 6v, and one for 12v, but one I hook the 6v charger to my battery, the needle on the charging gauge doesn't move. So I'm wondering if it's actually charging, or if it's broken. I'll see what I can figure out with a multimeter. | | | | | Joined: Mar 2010 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 119 | The newer chargers won't turn on if the voltage is too low in the battery. The Optima battery site has a procedure to connect another fully charged battery to the dead one to let the charger turn on and charge both till the dead one gets up to min voltage. Then charge the low one like normal. This may work for you.
| | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | That might be what's happening....Thanks for the tip! | | |
