| | | Forums66 Topics128,164 Posts1,057,081 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | To adjust lifters on 216-235-261. Here is the correct procedure. First- Your valves are laid out this way- from front to back- #1 exhaust, #1 intake #2 intake, #2 exhaust #3 exhaust, #3 intake #4 intake, #4 exhaust #5 exhaust, #5 intake #6 intake, #6 exhaust
This procedure can be used on either Hydraulic or Solid lifters. Just know which kind of lifters you have for final adjustment. Turn the crank (by hand) until #2 cylinder intake valve (look above- it is the third rocker back from front) is observed to start opening (that means the rocker is pushing the valve down and open). Now turn the engine slowly and notice that #1 cylinder exhaust (first rocker)valve will also start to open. Continue cranking until #2 cylinder's intake valve is wide open, AND then notice that #1 exhaust valve is also coming to the wide open position. (#1 exhaust valve lags a little behind #2 intake valve) Continue turning (slowly) until both valves are wide open. With these two valves wide open adjust: Solids: intake-.006. exhaust-..013 (special note: if this is 1 1/2-2 ton truck exhaust is .020) Hydraulics: adjust until just touching and no or very little wiggle of rocker can be felt. Adjust: #1 cylinder intake #2 " exhaust #3 " both #5 " intake #6 " exhaust
Now turn the crankshaft one full turn until #5 cylinder intake is observed to start open. Lagging behind will be #6 cylinder exhaust. Continue turning the crank until both of these valves are wide open and then adjust:
#1 cylinder exhaust #2 " intake #4 " both #5 " exhaust #6 " intake
Now you engine will be ready to start and let it idle for 30 minutes till completely warm and do the final adjustment.
It has been brought to my attention that I didn't give the final adjust for hydraulics- Tighten down until no noise is heard (use a section of hose to your ear and to the tappet if needed) then tighten one(1) complete turn.
If you don't know whether you have solids or hydraulics- Pull the rocker cover, loosen one rocker, pull the push rod, drop the side cover off, pull that lifter. Now take it to a machinist or mechanic and ask him which it is. OR, once you have the lifter in hand look to see if it has a hole in the cup (top) end and will push down in the center, if it does it is hydraulic if not it is solid.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#6274 06/11/2002 12:54 AM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Thanks OLY! Chevyboy62
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Jun 2002 Posts: 40 Member | | Member Joined: Jun 2002 Posts: 40 | Thanks, Oly... that was going to be my next question.
'48 Chevy 3/4ton 5 Window Deluxe
#6277 06/13/2002 11:36 PM | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | I believe there is a typo in Oly's message. I don't own one to know for sure, but .0006 sounds too tight for clearance on the intakes with solid lifters. I would imagine you meant .006, easy mistake to make. I just don't want anyone to adjust their valves wrong and have to go back in there to change them.
Aaron | | |
#6278 06/13/2002 11:45 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Good eye, '65. I missed that one the first time around. I like to think I'd caught the mistake as I was looking for the .0006" feeler gauge. chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#6279 06/13/2002 11:54 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Yes I missed that bit of a typo. but I could have been thinking I was rebuilding a turbo jet engine-LOL It is six thousandths, not six ten-thousandths.
| | | | | Joined: Nov 2001 Posts: 9 Member | | Member Joined: Nov 2001 Posts: 9 | Thanks Oly! That's one for the printer... | | |
