8 members (3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, Joe H, Joe Lowe III, 1 invisible),
77
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | What potiential problems could come from using this engine, it is standard rotation. I know it does not have a vacum advance.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | It'll always wanna go for a swim! | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | it requires lots of cooling - boats have the worlds largest radiator under them, that is why they can get high power outputs from small displacements
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | You'll need to swap distributors for a passenger car/truck type with a vacuum advance, or the gas mileage will be lousy. Im general, the Mercruiser engine will be somewhat of a hotrod, with a more radical cam and higher compression, so running midgrade fuel would be a good idea. I think some of them ran a 2-barrel carburetor, which would also boost the high speed performance a little. You'll encounter a slightly choppy idle from the cam upgrade, so a standard transmission or a higher stall speed converter if you run an automatic trans would be advisable to prevent bogging down at low speed. Jerry
| | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | then when i checked my compression today it should not have been 130,130,120,120,110,90. new rings i guess
