6 members (Woodcmiami, MNSmith, Otto Skorzeny, Guitplayer, Lostbuthaulinass, Gray_Ghost), 61 guests, and 1 robot.
Topics128,057
Posts1,055,812
What potiential problems could come from using this engine, it is standard rotation. I know it does not have a vacum advance.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
It'll always wanna go for a swim!
it requires lots of cooling - boats have the worlds largest radiator under them, that is why they can get high power outputs from small displacements
You'll need to swap distributors for a passenger car/truck type with a vacuum advance, or the gas mileage will be lousy. Im general, the Mercruiser engine will be somewhat of a hotrod, with a more radical cam and higher compression, so running midgrade fuel would be a good idea. I think some of them ran a 2-barrel carburetor, which would also boost the high speed performance a little. You'll encounter a slightly choppy idle from the cam upgrade, so a standard transmission or a higher stall speed converter if you run an automatic trans would be advisable to prevent bogging down at low speed.
then when i checked my compression today it should not have been 130,130,120,120,110,90. new rings i guess
