7 members (NJC, klhansen, kades51, MRMEROTH11, Eisenholtz, TexasA&M48Truck, Wickedbass), 68 guests, and 2 robots.
Topics128,066
Posts1,055,875
Members48,428
#477869 12/03/2008 7:51 AM
I think this belongs here. Hey fellow bolters smile I am wondering if anybody sells a frenched headlight kit? I was watching a T.V. program this weekend and they were working on a 53 pick-up and in the process of frenching the headlights on it which looked really neato-torpedo! It looked like it was a kit but they didn't mention where they got it from which is odd because those shows drop names like nobody's business
Hi Rusty...You could check out these guys , they may have just what your looking for.
Hope this helps
Jock thumbs_up
More pix on Flickr.
Geez that is a little more then what I wanted to spend I wish i knew how to do it myself
I know they aint cheap! eek By all accounts they seem to be the best though.
I love their headlamps but they're set up for driving on the right! (They dip to the wrong side!) dang They're pretty expensive too!
Jock thumbs_up
More pix on Flickr.
Autoloc also sells a frenched headlight kit. But they are about the same price as the above mentioned. With some work Id think you would beable to make your own. Time to research!
Here's how us old guys french headlights. Remove the headlight bucket from the fender. Drill 4 holes on the flange on the fender and remount the bucket from the backside, inside the fender using 1/4"-20 bolts. Take the original headlight trim ring and weld it to the fender. Grind your welds , and do whatever body work is necessary to smooth everything out nice. Replace the headlight bulb in the bucket and bolt back on thru the inside of the fender. The only drawback to this method is when aiming/adjusting the headlight beam you have to remove the bucket, turn the adjusting screw a bit, remount the bucket etc, etc until the alignment is complete.
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
Y
Y Offline
lmc sell a jewel headlamp kit.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
i agree use theese or the old merc bezels they sell to make your own. the hagans look like pie plates to me, to big.
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
Ex Hall Monitor
Ex Hall Monitor
Give Reliable Power Products Group, Inc a call. They have a frenching kit that is easy to use and priced appropriately.
powerblocktv.com did a 49 this weekend on the show trucks. If you go to the website and follow the link, they will list suppliers as well as a video of the show on how they did it. Not really my taste personally but to each their own.
The set up from the website they used for parts was much cheaper than Hagan if I remember correctly.
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
