Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Steveoreno, Otto Skorzeny, red450IH, 50Chevy3100), 177 guests, and 3 robots.
Topics128,288
Posts1,058,581
Members48,492
59 1/2 ton,235. I dualed out with fenton headers. I have stock manifold & stock rodch carb. Having a terrible time getting the linkage rod bent to go up through headers to carb. Does anyone mgf one or am I just holding my mouth wrong. Ive seen linkage for dual carb but not single. New to this. Need help (obviously)
The linkage does not go up through the manifold where the stock rod went. You have to shorten the gas pedal pushrod, or, as I did, make a new rod up. I did not want to cut up the original part. You need to move the bell crank mechanism back to the bolt hole near the rear freezeplug-then run the link to the carb up from there. Patrick's has a great kit to do that, and he helped me out when I called him about the same problem that you are having. I can imagine your frustration level...I experienced the same. Good luck!
Thanks for the help. I will take your advice.I was about to reach my end. There is another bell crank pin about 6 inches behind the other. I guess that would be the one Id use. Again thanks for your reply. Im new to this and this was my first post.There seems to be a wealth of help out there. Thanks again...
