3 members (F100Ranger, Bill Hanlon, latroca52), 147 guests, and 2 robots.
Topics128,192
Posts1,057,350
Members48,469
Does anyone know a secret to installing the headliner? I have the rear section in just fine but the front just doesn't want to go into place in the divider. I'm ready to put shag carpet on the roof! Also, is the only thing that holds the harmonic balancer on the square key? I see two bolt holes that go nowhere and I think they are for a puller? Thanks in advance for the help! Bob
when I did mine I put the front in first with the divider. It was still a bear to get in.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Ditto on front side in first.
Those 2 holes in the balancer are for a puller as you said, the balancer is a press fit. Some have drilled and tapped the crank snout for a bolt to make sure it doesn't come off.
Bob, your interior question should have been posted in Interiors and your engine question should have been posted in Engine and Driveline. It makes it hard to move a post to the right place when there are two questions that go to different places.
Don't feel bad about the spanking; we all get one from papa Charlie once in awhile.
But all that aside Bob. The balancer is a light press fit. You have to conceder that all of the thrust on the pulley is radial not axial so it doesn't take much to keep it on the crank.
A lot of the guys just drive the balancer on with a persuader and a block of wood. I'm not nuts about that method because of the chance of damaging the rubber support cushion between the hub and balance ring. A better method but one that requires a bit more work is to drill and tap the crank (7/16-20NF)and use a “Harmonic Balancer Installer” which pulls the balancer hub up against the stop on the crank snout. You can borrow the installers from places like AutoZone. There are a couple of pictures on this page of how I solved the drilling/tapping and seal alignment on mine, might give you some ideas: http://www.pbase.com/dennygraham/tools_of_the_trade&page=1
As fur as the headliner goes, can’t help ya there, I taint been thru that exercise yet. It’s funny, but for every one that says it’s a bear, I hear from another that says it’s a piece of cake. Knowing all the trouble I make for myself over the simplest of tasks, I’m sure that I’m in for a battle when I get around to the headliner.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
It's Oscar night so I will keep my comments short. Green T'Mater and Waldo...thanks, I will try the front first. Charlie...sorry, I won't do it again. Denny...you are incredible! I am a toy salesman not a talented engineer like you so I used a block of wood and a persuader. It all worked out just fine. Thanks for the help! Bob
D@C Offline
Denny
do you have the dimensions for making a hand crank?
David from Az again.
1951 Chevy 1/2 pu
Restoration/stock
Deluxe Cab
Five window
Denny G
Sandwich, IL
