6 members (3800GUY, BC59, Youngin' Tut 59, Gray_Ghost, dt235sd, 1 invisible), 126 guests, and 2 robots.
Topics128,140
Posts1,056,771
Members48,454
Can the solid tickitty ticking lifters in my Big GMC V-6 be replaced with Hydrolic lifters ? . . .
The yearly adjustment's, constant ticking dose get to ya after several 9-12 hour days in a row . . .
Truck run's 58-62 psi oil pressure so it has the oiling ability to pressurize them ?
Mike
1962 GMC K3000, GMC-379 V6.
Mike:
You need to check with the folks on the GMC site at
http://www.6066gmcguy.org/
I believe you will have to have your cam reground in order to use hydraulic lifters, but the folks over there can tell you defintively. Have you tried adjusting what you have to eliminate the ticking to no avail?
regards,
Steve
New Orleans
