0 members (), 135 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#62639 07/07/2006 4:23 AM
Does anyome have a reference to check bellhousing casting numbers? I'm trying to figure out what I have here. It's cast iron and has the 50's era crossmember mounts cast in.
The casting number is: 3733373
The date code(?)looks like: L 1 6
Other marks: GM1
I'm really trying to determine what year this is and whether it's a truck or passenger car bell housing. Any help would be greatly appreciated!
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
#62640 07/07/2006 5:04 AM
3B Offline
Hy Old Gold, I could not find that number in my books from 55-59, I'm assuming from the date code it was made in 56. Quite often casting numbers are not the same as part numbers. Could you give us some more clues, is it a V8 or 6 housing, does it have an angled mounting surface or is the mount surface parallel to the ground, is there one hole in each mount pad or two?
#62641 07/07/2006 5:14 AM
Can you post a picture? That might help as well. I think 3B is on the right track that it is a '56 casting. Possibly November 1 1956. Hmmm, that would actually make it a '57 part.
Bill Burmeister
#62642 07/07/2006 7:07 AM
Thanks for your help guys. It's for a V8. The mounting pad surfaces are slightly angled and there is only one bolt hole in each mounting pad. Does that help at all? I will try to post a pic tomorrow.
Mike
#62643 07/07/2006 9:18 PM
It could be for a Corvette. This guy has one with that # listed for sale.
http://www.corvettepartsman.com/index.asp?PageAction=VIEWPROD&ProdID=2577
-Tom
1950 Chevy 3100 w/ 1956 235
#62644 07/07/2006 9:52 PM
That bellhousing 3733373 is for trucks 8 cyl. 1955-59.
#62645 07/07/2006 11:13 PM
Thanks chevyb! I was hoping that was the case, 'cause that's what I need! Can I ask where you found your info? Thanks again.
Mike
